hi from Colchester UK
Essex, UK
Hi all im Aron From Essex UK
Been a pilot under a week lol jumped straight in the deep end and bought a mavic mini
this is because my friend had one and i loved it so much
anyway ive been flying it non stop since i got it filmed a few videos that i will share of course
any tips with range settings etc that i can use would love to hear back
Def still learning yea ive been careful so far i fly minimal of 100 ft to be on safe side
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. You'll have to scroll all the way East to get to the UK…
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Happy, Safe and Legal Droning…
yep already know and read it all :D
Welcome to the forum! :)
Roel Hopstaken
