Picked up a Mini SE last week.
Welcome from the Hampton Roads area of Virginia, USA. I fly a
Mini 2 and I know the excitement you are going through…
Below is the DJI Link for advice on flying in the UK, be sure you are following all of the laws and rules applicable to you.
United Kingdom - Flying Tips - DJI
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy and Safe Droning…
