Hi from London
Mr Bowcat
London, UK
Hi All,
Bob from London here. I'm a complete newbie at drones, so just bought myself a little Mini 2 SE to get started.
Unfortunately I've immediately run into some issues in that I live right on the outskirts of the RAF Northolt restricted flight zone, so can't even take off in my own back garden. On top of that I found out that the London Borough of Hillingdon (where I live) has a complete ban on the use of drones in public parks and spaces. Looks like I will have to travel a little further afield for my first flight.
Hey Bob
Welcome on in, and indeed to the constant battle to find places to fly...
That is most unfortunate placement in terms of FRZs and local council hostility. That whole area is notably empty of suggested fly sites in Dronescene until you get quite a way out of it alas. So I guess in your position I would be best planning a lot of day trips down South !
Since you live in UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2 SE, including the User Manual.
Fly On and Fly Safe…
Just a quick note, I am in the US and I live near an Air Force Base and I also could not even fly in my own yard. Here in the US, once you get your Part 107 Certification (lots of studying and pay for an Exam and pass) you can qualify to get what I would call a commercial license and with that I am able to get authorizations to fly in these Zero Altitude Quadrants. I do not know the rules and laws in the UK but you might want to look into that…
In my previous post, I included a link the Rules and Laws governing the flying for Drones in the UK…
Below is a map of my area, the Blue areas are restricted military flight areas, the Green is a controlled International Airport, and the Red are National Parks (no flying at all…). And I am the little Pin in the center… Oh, and by the way, the county that I live in also prohibits flying drones from any of its property (schools, parks, public areas, etc…).
Thanks for the warm welcome guys.
I did my due diligence before buying the drone, so have watched hundreds of YouTube vids, read the manual a few times, and obtained my Flyer & Operator ID's.
I can apply for permission to RAF Northolt, however if granted this is only for a specific time slot on a specific date. I guess it's for commercial purposes, but wouldn't let me fly in my garden whenever I want.
I have sisters in both Southampton and Somerset, so looks like I will be seeing both of them more often, not a bad thing anyway. :)
I also work in Hemel Hempstead which appears to have a more relaxed approach to flying, and is not near any RFZ's so will be spending some (dry) lunch breaks at the local cricket pitch or park.
I would recommend you try this and apply. It might be more generous than you think, you might be able to get a whole day, a whole week, etc... and it might even be renewable, As I wrote previously, Ihave numerous FAA Authorizations, each is for specific time slots, (Sunrise to noon, Noon to 4 PM. and 4 PM to sunset -- Yup that's all day, I did not apply to fly at night...) and each is valid for a specific date(s), all year and they are renewable with a simple click of the mouse...
As the expression goes, ""Try it, You'll like it..."
Good Luck
Reactions: Mr Bowcat
Welcome from the west Midlands.
NFZ's and other flight restricted areas are definitely spreading over the UK and local councils are getting to be a PITA but at least it gives a reason to broaden our horizons.
Don't be put off by the 'apply for permission' situation, a lot of ATM (Air Traffic Management) concerns are a lot more approachable than you might imagine, especially the military ones. It does help if you have a reason to want to fly in a particular location, to shoot a particular location or feature for example.
When you've jumped through the hoops once or twice, it gets familiar and you'll find the process a lot easier, ATM providers share information and if you have a good track record as a responsible operator: this will follow you around and grease the wheels in other areas.
KiKiHUN
