Hi from Murcia Spain
Hi from Murcia Spain….. googled what is the best forum for DJI drones and you popped up. Looking to buy the Air 3s so will surf and see what you guys think 👍🏻
A big welcome to the forum from the UK!
I have the Air 3s. Awesome drone, not perfect but I love it.
What kind of flying are you doing?
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Air 3S, including the User Manual.
Fly On and Fly Safe…
Reactions: Mrktn and Hauptmann
Thank you so much for your response…. Some very helpful tips for a newbie 👍🏻
Non at the mo…. Have no drone but looking to see what you guys think of the air 3s I hear so much about
Poorly worded, sorry. I meant hoping to do. Video? Photography? Countryside? Urban?
Will then be in a better position to offer advice.
carlitoperez
