Hi from Nova Scotia Canada
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Hello from the Crossroads of America djtino.
Nice to meet you Dominic. 🤝
Welcome to the Forum. :cool:
i just move to nova scotia and bought a DJI Mini 2
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Welcome from Ft. Myers, Florida! As the weather gets colder, make sure to keep your batteries warm before flying.
We don't have that problem where we live. 🤣
Welcome to the forum! :)
JefScot
