Hi from W. Sussex
Welcome to the forum. We look forward to your participation and your view of the world.
Hello from the Crossroads of America Sleepymouse.
Good luck on your flights and welcome to the Forum. :cool:
Noobie from Worthing.
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Be sure you are following all of the laws and rules applicable to you in the UK. Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the Mini SE. You will also find the 47-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini SE - Download Center - DJI
Happy and Safe Droning…
Hi Everyone
Decided to start small and got a Mini SE. Not flown it yet but hoping to in the next couple of weeks, either at Goring Gap or The Gallops, Worthing. Little nervous but hoping to have enough practice before a trip to North Wales next month.
Welcome from Ontario Canada
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Hi Everyone
Great bird. Have fun, take your time learning. Before you know it the drone is like an extension of your body. 👍
Hi Everyone
Welcome to the Forum from Len in South Wales, enjoy, cheers Len
Hi Everyone
Welcome to the forum Sleepymouse from the Texas gulf coast!
Greetings from Birmingham Alabama, welcome to the forum!
Hi Everyone
Welcome to the forum from the beautiful Rocky Mountains of Colorado! Happy and safe flying!
engmarceloacs
