Holystone HS 175 d app stoping.
Bodidly
Tn.
New to Drones and already enjoy flying around the farm and the neighborhood.But have been running into problems with my Android phone and the app.I have had the holystone HS 175 d for about 2 months and everything fine and now get promp after calibration that says Sorry the program is abnormal the app collecting logs and ready exists.The app is HS gps v5.I can use my son in laws I phone with no problem .I hope this post in in the right section,thanks for any help!
Bo
Do check out the Holy Stone Drones Forum
New to Drones
Hey Bo,
Already welcomed you at Drone Pilots, but you get a welcome here too…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Tennessee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
I fly a DJI Mini 2 and I do not have any knowledge about Holy Stone, but here is the link to all of the Holy Stone User Manuals and all their Apps…
Fly On and Fly Safe…
Chad Howard
