Home made - Discharge Mavic Mini batteries without running the motors.
That article doesn't seem to distinguish between Li-ion and Li-polymer, e.g. it says "Figure 1 illustrates the capacity drop of 11 Li-polymer batteries," but the caption for Figure 1 says "Eleven new Li-ion were tested..." I'm afraid that's just adding to the confusion.
Look to figure 3. The info is corroborated a number of additional sources.
"Lithium-ion suffers from stress when exposed to heat, so does keeping a cell at a high charge voltage. A battery dwelling above 30°C (86°F) is considered elevated temperature and for most Li-ion a voltage above 4.10V/cell is deemed as high voltage. Exposing the battery to high temperature and dwelling in a full state-of-charge for an extended time can be more stressful than cycling. Table 3 demonstrates capacity loss as a function of temperature and SoC."
Corroborated here:
My point is, that article seems to consider Li-polymer to be a Li-ion cell, so it isn't clear that what was tested and what was found actually applies to 18650 cells, which is the issue that has been raised.
Reactions: Dbez1
It seems more like a typo. It's constant the rest of the article. It's also constantly similar info to numerous other sources. I guess I would just need to see anything anywhere that suggest that storing at full charge is considered best practice.
But I don't see anywhere in that article (or elsewhere on that site under the same heading) that distinguishes between Li-po and Li-ion, specifically 18650s. Treating them as the same thing is exactly the issue, and I believe the specific claim is just that storing 18650s at full charge is not as damaging as it is to Li-pos.
I added more sources to my previous post. One specifically mentions the Samsung 18650 and corroborated the article. I think they mentioned lithium polymer by mistake. They are specially referring to Cobalt based lithium ion batteries (same as Samsung 18650s) as stated in several places.
I am not trying to convince you of anything. I just can't find info that supports your position. Which was in fact the same as mine until I started to do some digging.
This is just diluting the OPs thread so I will let others decide for themselves now
that I have shared what I dug up.
My Nikon D7100 DSLR uses Li-Ion batteries and I keep them fully charged all the time. After 4-5 years, they’re as good as new. For convenience, I’m keeping my MM batteries fully charged.
Same here leave them fully charged on my Nikon always
Reactions: Dbez1
When 18650s are used in battery packs, they're usually spot welded. What I'd really like to see would be a battery mod that allowed you to easily pop in a fresh pair of cells. I have several DIY power banks that hold 18650s just using clips similar to those used for AA batteries.
Silver solder
SaffainNL
