the outputs of the usb ports on the charger brick are not suitable for charging the main battery, they are only for the controller or your deviceI’ve got a charging brick with two USB ports that I would like to be able to use for charging MA2 batteries in the field. Is there some kind of connector that will allow this? I tried hooking into the AC with the USB C cable, but it didn’t charge the installed battery.
This will work for you. AC Outlet Portable Laptop Power Bank, Universal 116Wh/31200mAh 100W Travel Notebook Charger & External Battery Pack for HP, Dell, Lenovo, MacBook (Black) Amazon.com: AC Outlet Portable Laptop Power Bank, Universal 116Wh/31200mAh 100W Travel Notebook Charger & External Battery Pack for HP, Dell, Lenovo, MacBook (Black): Home Audio & Theater
I tried that but got no indication that charging was happening. Maybe the power feed wasn’t strong enough.I charged my M2P battery by plugging a power brick into the USB-C port on the drone with the battery in it. It charged the battery fairly quickly. Perhaps someone will tell me it's a bad idea and I won't do it anymore, but it worked.
I’m surprised no one has a definitive answer. I definitely charged my M2P with a power pack. I was on a bike ride and one of the 3 batteries I brought wasn't charged. I used an Anker USB power bank w/ 3 smart IQ outputs (5v) plugged into the M2P with the battery in it. The battery light was blinking as they would in the AC charger. It added about 60% in a couple hours I think. I couldn’t say whether it’s safe or not, but I don’t think 5v is likely to burn it out.
