Okay, this seems ridiculous, but I cannot get the micro sd card out of my mavic mini. If I have to leave it in there, will it just keep recording over the old files at least?
If you have fingernails, just push up against the edge of the card where it's mounted inside the mini. It's spring-loaded, and will just pop out a little towards you, and then you can pull it out the rest of the way. If you don't have fingernails, try pushing a pen cap or something of similar size against the edge of the card that you see while mounted in the mini, and it will pop out a little.Okay, this seems ridiculous, but I cannot get the micro sd card out of my mavic mini. If I have to leave it in there, will it just keep recording over the old files at least?
I recently had an SD card hang up in a camera even after the catch had released, but I was able to remove it using the tweezers from the miniature Swiss army knife I carry on my key ring. My greatest "life tip" is to get one of these knives. I've carried one (not the same one) for nearly 50 years and I generally use it a couple of times a day.
The sd card is spring latched. Press until it clicks an it will pop out. Be careful to keep your fingers on it, as I have had one pop out into the snow on the ground. I carry a pair of tweezers I my case to help. Re-insert the same way, press until it clicks and latches.Okay, this seems ridiculous, but I cannot get the micro sd card out of my mavic mini. If I have to leave it in there, will it just keep recording over the old files at least?
Use a ball point pen tip. Push in firmly and it will pop out enough to grab it. Works for me every time.Okay, this seems ridiculous, but I cannot get the micro sd card out of my mavic mini. If I have to leave it in there, will it just keep recording over the old files at least?
I add a piece of clear tape to the end of the card folded over, so there's a little flap hanging out. This makes it easier to grab and pull after pushing it in to release. (Did the same on my MA)
