As shown just above, there are videos showing how to do it, but I doubt disassembly is needed. Look at it closely and see if you can tell which direction to pry it, gently, with a plastic or wooden tool. It should pop back into place. If you have any phone/tablet toolkits they should include a plastic "spudger" which is the perfect thing to use. If you're careful and dextrous, a small metal blade screwdriver would work, but metal is more likely to scratch or leave a pry mark - hence the plastic/wood recommendation.View attachment 20975 Had a slight mishap with MP while transporting. How is the upper shell removed to fix a slight separation between the upper and lower shell?
Removing the screws also just voided your warranty as an FYI.Thanks all for your suggestions, especially the video. Got it snapped back in place. I ended up removing the screws as shown in the video, but didn't need to take the shell off. Apparently, removing the screws allowed just play to snap the cover back.
How would they know? There not a warranty seal on them?
There was on one of them. You probably didn't notice. By jamming the screwdriver into the slot, you may have dislodged the seal in it.Actually needed to remove the screws: four in the battery compartment, two rear ones on top, two under the front arms holding a small cover plate, two under the cover plate, and two over the forward vision sensor. The above video shows this in great detail.
There is no warranty seal on the screws.
