How many batteries are to many?
  • Thread starter Thread starter Deleted member 3792
  • Start date Start date
I have 5. Three came with my Air in the flymore bundle, and I bought two more. I am still learning how to fly this thing, and find myself going through all 5 in one session. My controller easily handles that much time, as does my Mini-iPad 4. I also bought a couple of used Mavic Air chargers that I can plug into the inverter I installed in my Chevy Volt, to simultaneously charge the batteries as I use them. That should increase potential flying time considerably.
Isn’t a Chevrolet Volt a overkill powerpack just for charging the Mavic? ?
Reactions: rainystateguy
I have five older M2 batteries with roughly 50 flights each (original and two Fly More Kits), so flight time is slightly degraded by about 10% on each. I recently got two more new ones to get back that lost 10%, so I still have time for a few panoramas, while flying the same distance as with the older ones. I can never have enough flight time! Besides, battery prices were just going up! I find four batteries is enough for an afternoon of fun, although I could actually squeeze in five 24 minute flights, based upon the RC battery and iPad battery life in the field, without any access to power.
Reactions: Thomas B
JohnMeyer: what about time to let the battery cool before changing?
That's a really good question. I forgot about that.
I have a little muffin fan that I modified to use as a cooling fan. It can easily run off the little 140 watt inverter I have for my car. I point it at the battery after I take it out of the bird and I cool it down for about 5-10 minutes before I begin charging. I also cool both the battery, the charger, and the controller (if I'm charging that too) while they are charging.
Heat is the main thing that kills batteries.
So, if I really wanted to have an afternoon of uninterrupted flying, I might need to re-do my calculations and get four batteries instead of three.
I only have two at present because so far I haven't needed to do that much flying in one location, all at one time.
I also have an DJI Spark with 5 batteries and a Yuneec Typhoon H, even that one with 5 batteries. My largest drone is a Sky-Hero little six. In that one I only have 3, but it’s 6s and in paralell so there will be 6 batteries in that beast. Here is those two drones. The big one is 580 mm in center of the motors and weighting about 3 kg. It lifts a Canon supershot sx740hs with 20 Mpix and 40 x optical zoom.719CECD5-5FBA-4D79-8A64-638A724A127D.jpeg
Compare the Spark with the Sky-Hero down below.
Any approximate time it takes to charge an M2 battery from say 35% to 100%?
I will give it a try this weekend. From my experience though it's around same time as wall powered AC charger. But will do a real test to make sure.
Thanks, really interested.
I could run through all 8 batteries. Should put me at 20 to 30%. Never ran through all 8 in a go. And still call for help if needed.
I only have 4. By the time I'm down to two, I start to charge in the field. I was thinking of a fifth battery but 4 has served me well. I guess some depends on how you fly and the conditions are always a factor. I also let my MP cool down in warm weather between flights so I don't usually fly back to back runs. My van has a 2000 watt inverter so I can charge like I do at home.
Hi, finally able to test it 3 times in the back country.
Charged battery from 5% - 10% to full and took around 1 hour each time.
Great. Thanks for the info.
finekio
