Impossible to Launch Mavic 2 from balloon (hot air) 1700m
Will Falcon
I was doing skydiving and didn't get any chance to launch my mavic 2 (pro and zoom) to film my jump and the sunrise environment... so sad.
So, why is that?
Could you explain please
So, why is that?
Need more details for a good answer. Maybe others will chime in.
Where was the drone?
The video is only 21 seconds. So time may have been a factor.
Ferrous metals in the ballon burner and basket may have interfered, or even some of your jump rig if you had the controller.
What flight mode were you in?
Burner components are typically stainless steel, so that may not have been an issue. Can’t remember what the tanks are made out of. Like anything that flys,(or blown around in the wind)weight is always a factor, so doubtful any steel. Maybe the wind blown folks will chime in.
Possibly an altitude issue?
So, why is that?
1700 meters over 5000 ft , might have shut down once realized is that possible.
Possible, but the drone probably would have had to have been on when you took the ballon up. Are the baskets reinforced?
Doubt altitude as I can take off from the desert floor, or from the top of a 1500’ cinder cone or a 5000’ mountain and the drone registers take off point as zero altitude. I use this trick to get to the top of mountains.
Reactions: Phantomrain.org
The drone on at balloon launch was my thought.
The altitude variable is reset on motor start, not power up.
Can you launch normally from a platform moving laterally, it would likely not be able to set home point.
If GPS is unavailable you'd be OK but not if there was conflicting sensor info.
Reactions: Peio64270
The warnings were uncommon, so I didn’t remember excactly what they said, something “can not initialize smth”, too much information in extreme situation and in a too tight space.
It was not a compass or a gimbal or etc... How to check the logs?
Aircraft has to stand reasonably still or it won't start motors. If you're rocking in the basket or not being steady enough when holding in the hand it might be too much for it.
But it's probably better that way. Unless you have your Mavic modified to give you ATTI mode and know what you're doing it would be VERY sketchy to start it there, it'll uncontrollably fly out of your hands with all the power it has as soon as the motors are started, and you'd better be on the correct side of the basket, well clear of it and with no vertical speed if you don't want rotating cutters into you and the balloon.
Without ATTI it'll also be almost impossible to safely land in the basket again, and you probably won't have enough flight time/range to go land it somewhere appropriate on the ground.
Very "advanced" move that requires full comprehension of how the thing works. Lots of people have had bad experiences on boats, this is even more difficult since there is less space, the balloon moves up/down in addition to horizontally, and damaging the much more fragile balloon due to a messup can have much more serious consequences.
BausInGV
