Appears the 1080p 60/96 is unusable.Explains why if you use 1080p mode you should shoot at 30fps and not 60. The 60 fps at 1080 is really for FPV when the goggles become available.
This was posted by DJI on another forum. I assume its ok to post here.
Yes, but many don't really understand why they are shooting in 4k or have a target for final delivery.I suspect many will shoot at 4k or 2.7k (better choice considering the bit rates) and if needed, down sample to 1080. That usually provides a better 1080 video. The Mavic Pro's camera was not intended for professional level video. I'm sure the limitations of cost, size and weight all played in to it. For the use it was designed, it's not a bad camera system. As noted the 1080@60fps was designed for FPV.
I'm fine as I have two Inspires but for portability I just wished the Mavic could do half decent 60fps.I always shoot at 4k on my pro equipment but don't consider the Mavic pro to be any where near a pro level video system. I'll shoot the Mavic at 2.7k. and while I would prefer to have a usable 60fps, for this level of chip and lens 30 will be ok. If you really need the 60fps get (or keep)
the P4. The Mavic Pro is not designed too be a replacement for the Phantom series.
I sold an Inspire for the very reason of portability. It's a great platform but portable it is not. I'm afraid I will be tempted by the Inspire II though. The Mavic should be fun if nothing else.I'm fine as I have two Inspires but for portability I just wished the Mavic could do half decent 60fps.
Oh well, it will only be a throw away platform so I shall have to make do with what it can produce.
Thanks for posting this. Interesting.Explains why if you use 1080p mode you should shoot at 30fps and not 60. The 60 fps at 1080 is really for FPV when the goggles become available.
Good quality slow motion is very hard to achieve, even on Panasonic GH4, one of the best consumers camera for video, 96 fps at 100 mbps is unusable.Appears the 1080p 60/96 is unusable.
Yet another indication that DJI are totally clueless in designing camera systems!
This is exactly the same document the OP posted to start the thread!Info from DJI about the Mavic camera's sensor and 60 fps.
Yea, I agree.Wow, and I always thought the Mavic camera had the same sensor as the P4 except with a different lens.
Looks like the sweet spot is 2.7K @ 30FPS = 60mbs.
4K isn't 100mbs = too much compression.
1080p@60fps = too much moire (softening fixes this to a certain extent).
Thought I was seeing double.This is exactly the same document the OP posted to start the thread!
