Installing Assistant Software Fails
FatherXmas
Mentone, Alabama
Has anyone else had an issue with installing the Assistant software on Windows 10? I get an error that the drivers are not signed and installation was blocked. I've tried to install on two different computers with the same results.
You can disable driver signature enforcement at startup.
  1. Press and hold the Shift key on your keyboard and click the Restart button.
  2. Choose Troubleshoot > Advanced options > Startup Settings and click the Restart button.
  3. When your computer restarts you’ll see a list of options. Press F7 on your keyboard to select Disable driver signature enforcement.
  4. Your computer will now restart and you’ll be able to install unsigned drivers.
Reactions: FatherXmas
Make sure you're not trying to install an old version. There is no signature problem with current release.
Thanks! That did the trick. When I ran the installer, a box popped with a warning about it and gave me the option to continue.
Reactions: DodgeP
I downloaded it this morning from DJI, so it should be the latest version. I followed DodgeP's directions to allow unsigned drivers - worked like a charm.
flydeep
