Invalid battery
Gilly562
New York
Have M2 Pro w/2 batteries, relatively new, Nov ‘19. No flying till recently. No issues with batteries using DJI charger.
Bought Hanatora 5-in-1 rapid charger to have car charge option for trip, but didn’t need to use.
Didn’t expect to be flying anytime soon so I discharged batts on Hanatora using storage mode.
Now one of my batts shows as ‘invalid battery’ in go4 app. All lights on M2 Pro are solid red. Tried discharging batt on M2 till
shut down and then recharging with DJI charger. Same problem.
Has Hanatora F’d my batt? Anyone else have issues? It’s of course out of warranty.
  • Sad
Reactions: Mr Shamrok
I've had no issues with the Hanatora 5 in 1. Sounds like maybe your battery went into hibernate mode? When you connect the battery to the Hanatora charger, does it recognize the battery and show voltage and start to charge showing charge current? Have you tried charging the battery on the original charger (direct, don't use the DJI charging hub)?
I’m sorry that the battery does not work for you. Could you describe in more detail what happens to your battery when you insert it into the drone. And what happens when you connect it to the original charge. But it looks like it has a blocked module.
Suilven
