- Joined
- Oct 22, 2018
- Messages
- 5
- Reactions
- 1
- Age
- 66
I was in a park and had to take off from an overlook that was in a canopy of tree coverage. I took off about 8 feet. Home point was recorded. I then flew out through the canopy with the alarms going off but the drone did not stop. I then flew and started to return home at about 25-30%. I really was not that far from the drone. As I attempted to bring the drone in I had to position the drone to make it through the opening under the trees. Just as I was bringing it in the drone started fighting me and then wanted to return to home. Returning to home would have meant the drone was going to go over the trees and then attempt to land through the trees. I was in a panic. I touched the x on the screen to cancel the return to home but it would not respond. I was trying out the crystalsky Ultra which I have found out has lots of issues with the touch screen among many other issues. Through sheer luck I somehow got the drone to stop returning to home. I got to the point the controller was like screaming at me that it was going to die with what little juice it had left. Finally I was able to fly it back in and land. My hands were trembling.
I had a similar situation when I needed to manually land on the bow of my sailboat. There are lots of rigging that makes landing a challenge . I almost had the drone on the deck when it when into a return to home and started the assent. I quickly had to navigate left to avoid a collision. This went on for several minutes. Finally the drone hit the lifeline. I miraculously grabbed the drone and saved it from landing in the water. MY finger was cut but I still had my drone.
My takeaway is to plan for the types of flights and the landing that is required. Before finally landing I should have hovered in a safe spot and turned off obstacle avoidance and RTH.
What are others thoughts or experiences
Here is the final flight I was able to capture
