the TDW mount for ipads and large android tablets has a lanyard attachment already fittedHas anybody sèen or come up with an idea for a lanyard mount for the remote ?
MA2 317" data-source="post: 1098021" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Heya brother. I'm not trying to jump your idea; however; I would advise not placing your weight bearing point directly on the antenna itself. It may not feel like there's a great deal of pressure on the controller when you're wearing the lanyard but after repeated use; and probably before too long; you could start noticing loss of signal or other interference with your MA2. If so it will most likely be due to a short in an internal antenna wire. Check out the website I listed below. They make a Pro Mount/Lanyard adapter that's absolutely outstanding. They are a little expensive but if it fits into your budget; they are well worth the expense. Good Luck and Fly Safe.New MA 2 pilot here sharing my quick solution for a lanyard.
I have flown the DJI Spark with a mini4 and a tablet holder for over three years.
But then I soon realized that I'll have to purchase more accessories for the new remote if I want to fly with the mini4.
Until I do, I'll fly with my phone.
I had some rubber O rings that I used to use as a battery strap for the Spark and the O ring works perfect for an impromptu lanyard on the MA 2 remote.
The O ring can remain looped on the remote and recessed with the supplied OTG cable when it's being stowed.
OP is looking for a lanyard to put on. Not a tablet mount.Hello All. Give this website a try. You can buy the lanyard attachment separately; although; I would highly recommend the entire MavMount assembly. It is the best tablet/phone mount I've seen on the market currently. It's designed by a Hollywood Film maker who flies DJI Mav Pro's and Inspires full time.
Front Page - Mavmount brand DJI Mavic |Mini |Air iPad Tablet Adapter
MAVMOUNT adapters work with every iPad and every major android tablet device that exists. Whether you’re using the folding or newer top mount DJI controllers, Mavmount has a rock solid professional solution for you. All Mavmount adapters use precision engineering for top fit and finish, supports...www.mavmount.com
OP can buy a lanyard attachment and a lanyard on this website. THey sell them individually or with the tablet mountOP is looking for a lanyard to put on. Not a tablet mount.
Way over priced though. You can buy one for 5 bux on fleabay and they work perfectly. Same with a tablet mount. Just sayin'.OP can buy a lanyard attachment and a lanyard on this website. THey sell them individually or with the tablet mount
Thanks for the advice guys! Just bought one off our favorite auction site.
Do you have a link?
