Leg Damage
rp05
Ireland
Hello im just looking for a bit of advice on if this s a big job but i just noticed the other day my propellers were hitting each other and upon inspection found damage to one of the legs on the drone am wondering if anyone knows what i should do would it be easy enough to fix myself from what i can see it could only be tightening few screws but i could be 100% wrong :).
Thanks very much in advance.
Please see attached pics20240306_132539.jpg20240306_132543.jpg20240306_132548.jpg20240306_132554.jpg20240306_132705.jpg20240306_132724.jpg20240306_132727.jpg
Reactions: Cafguy
You can try to Remove the screw on the leg and slipping it back on BUT Your rear arm axis has most likely become damaged and MAY need to be replaced. the arm itself could also be damaged and should also be replaced if you find any kind of damage..
How hard the fix is is up to you. Are you new to electronics and working on drones? If so you can still do it just TAKE YOUR TIME.
For me it would be a simple fix, Probably for you to. Watch a few repair videos on YouTube and give it a go.
Hopefully the leg will just slip back on and your fixed.
IT looks like it has been in a crash.
thanks very much for the reply it was in a minor crash as in i was able to see it so know it wasn't extreme so probably is from that but have been flying it bout 10 to 15 times since with no problems so must have gradually loosened or damaged. I will have a go myself as i think im half competent but will do exactly that and take my time again thanks for the reply
paul44509
