Check out these search results.Which is better litchi or DJI go?
Don't think of it as one or the other.Which is better litchi or DJI go? Is it worth paying for litchi?
Very easy, once you understand all the parameters. It is especially useful for repeating missions. Just be mindful of elevations and obstacles. When a mission has it flying sideways to capture an image the sensors may not detect an obstacle and fly right into it. People also get a false sense of security because Litchi will continue a mission if contact is lost. What happens is winds aloft may be stronger than planned for and it will deplete the battery before regaining contact. Then it is lost with few clues where to find it.Is it easy to use waypoints?
Meta4, can you install and run both, Litchi for waypoints, DJIGO4 for general flying? Would that split up your captures and flight record into two parts?Don't think of it as one or the other.
They each have their good points.
DJI Go is better for general flight and photography and Litchi excels for waypoint flying.
You can install both but you cannot use them together.Meta4, can you install and run both, Litchi for waypoints, DJIGO4 for general flying? Would that split up your captures and flight record into two parts?
if Go 4 is having problems?It is also nice to have Litchi available if Go 4 is having problems.
A Go 4 update hosed my video but Litchi worked fine. I had to downgrade Go 4 to make it work again....I don't think I've ever heard of a situation where Go 4 is having problems....
