I need help from the Litchi community
I am flying a route with 95 waypoints starting at an elevation of appr. 265-m above sea level at Waypoint no. 1 (takeoff location). See attached link. Waypoint no. 95 is at appr. 778-m above sea level. I programed the flight at 251-m above ground level all the way from waypoint 1 to waypoint no. 95.
You will notice that everything appears OK until waypoint no. 65 where the waypoint's icon will shows 2 altitudes, the altitude above ground of 251-m (yellow) and the calculated altitude of 500-m (white) relative to the take off point. Subsequent altitudes (white) relative to the take off point keep showing 500-m although elevation keeps increasing as we move through the waypoints to waypoint no. 95.
Please review and let me know what I need to change and why the altitude relative to takeoff point stops at 500-m. I am concerned that I may fly into ground or a tree as I keep flying the route to the last waypoint as the elevation increases to 778-m above sea level.
Thanks for your ideas and recommendations as always.
Mission Hub - Litchi
Litchi's Mission Hub lets you plan waypoint flights and later execute them using the mobile Litchi app.
flylitchi.com
