Lost my drone here is the flight log.
  • Thread starter Thread starter Deleted member 106156
  • Start date Start date
Status
Not open for further replies.
D
Guest
Flying a little over 5000 feet away and lost connection. Had a good signal, just boop and then nothing. I flew into the wind to get to the destination and I believe it should have take the drone less than 3 minutes to get back home. It was at 64% when I lost connection I think. On my previous flight earliar that day, when I landed I had 44% left.
Thanks guys!
Log- DJIFlightRecord_2019-08-31_[16-15-52].txt
Reactions: denar
Your flight data looks like this: DJI Flight Log Viewer - PhantomHelp.com
At the end of the flight data, the drone is in stable flight making 30 mph with full right stick in Sport Mode.
There are no sudden changes in the pitch, roll and yaw data that would indicate a collision or flight problem.
You had lots of battery and no obstacles on the RTH path.
Your Loss of Signal action was set on the default (RTH).
That leaves a sudden loss of power as the most likely cause of loss of signal.
Reactions: Donnie Frank
Thanks guys. I contacted support so hopefully they can offer a replacement. Additionally me and 2 other people spent probably 2-3 hours searching its last known and didn't see it, but there was a lot of tall grass.
Could the US Navy testing affected it?
Was the navy testing something that completely blocked all communication to/from the drone?
If you are thinking of GPS interruptions, we'd still have full communication with the drone rather than the data just stopping.
Per that article:
"GPS aerial navigation could become unreliable or unavailable again over the southeastern United States and adjacent coastal waters during a U.S. Navy exercise that will involve GPS interference testing this Friday, Aug. 30, and next Thursday, Sept. 5."
Your flight was on August 31.
At a distance of ~540 miles from the GPS testing, he would have had to be flying at >30000 feet to see any effect.
And GPS interruption would not cause the drone to fall from the sky or have any effect on the drone's telemetry.
There are no precursor indications of any problems, so it does look like a sudden loss of power or FC failure. If that's what happened then it's descent track, based on position, wind field and aircraft velocity, should look something like this:
Have a look at my thread about a very similar disconnection and loss, and also some of the other threads about the same issue. Makes me think that there is a software or firmware issue somewhere.
or a battery coming lose, or a battery cell(s) failure..........
SAR104, are there any indications in the logs of battery issues?
Bird tips drone.... drone hits ground... battery ejects... sudden power loss?
Status
No members online now.
osje
