- Joined
- Apr 6, 2018
- Messages
- 4
- Reactions
- 4
- Age
- 25
Hello! Lost my Mavic air, the signal disappeared and I couldn’t find it on the place it was suppose to be before it lost signal. What should I do???Moreover, I think that the battery died
I'm not the expert, but I can tell you what you did wrong. You didn't wait for the home point to be set when you took off, as a result, the HP wasn't recorded until 57.8 seconds into the flight. In the Google Earth picture below, the green pin is roughly where you were standing (taken from the app GPS which isn't always accurate), the yellow pin is where the HP was actually set, and the red pin is the last know point of the Mavic. The Mavic still had around 75% percent battery so I assume that when signal was lost it headed back to the recorded HP (yellow pin) I would advise searching in this area.DJI Flight Log Viewer - PhantomHelp.com I still don't understand what happened
I'm sure there are lots of things things I'm missing so I'll call in @sar104 to help us
out.
Again, Green = you
Yellow = Home Point
Red = Mavic's last known location
This first picture shows the flight path along with the various pins.
This second picture shows the pins and my estimated rout between from the last know point and the HP.View attachment 35225
The last pic just shows a close up of where the HP was set.View attachment 35227
My only suggestions at this point would be to maybe put up some posters offering a reward in the area of the home point. Also if you walked the estimated RTH line starting from where @sar104 took the google image, you may also find it because, as Sar said, your Mavic may have been stopped by obstacle avoidance in front of one of those buildings and hovered until it landed. Good luck! -CFThank you for your help, your answers make a lot of sense. However, I have looked for the drone where the connection got lost and where the fake HP was set without any luck
