First note: I'm *only* talking about the Smart Controller itself in this case.
I just got the SC and am using it with an MA2. Controls it just fine and can fly without issue. After opening DJI Fly it quickly will show 12+ satellites fixed.
However, I noticed that on the map in DJI Fly the RC position way off.... 50-100ft sometimes. Which, of course, makes it such that the "aircraft orientation" display in the bottom middle of the UI is all kinds of wonky in terms of showing that the MA2 is behind me when it's in front, or similar.
So, I installed an Android app I've used for a long time called "GPS Status & Toolbox" and went outside. Drone shows 13 satellites fixed. My phone shows 14 fixed. The SC shows **3** satellites fixed
It bounces back and forth between 2 and 3 fixed which is obviously not enough to high accuracy. I've tried going into "Location" settings and setting it to each of the 3 difference accuracy options.
I've used the aforementioned app to clear the AGPS data and reload it. I've waited outside for 30 minutes. But it never goes above 3 fixed.
Any thoughts what I might be doing wrong? It's not the end of the world but pretty annoying since the stock MA2 controller with my phone is better at showing my orientation to the drone than the very expensive SC :/
