M2P controller only charging to 97% and no further.
This anomaly has just happened today and I've had the unit for over 2 years. Anyone else had this happen? Thanks
Mine has done the same thing. Seems it’s due to cycles and age on the battery in the controller. I have not found it to be a problem.
I did buy a couple of controllers in near new condition as backups. If it becomes a problem I’ll just pair one of those with my M2P.
Reactions: mrjohnc1
Mine did that, but topping it off a couple times got it to fully charge. However as was stated, 97% isn't a problem. The only caution I would make is not to leave it on charge too long if it remains in charging state with no increase in charge level.
Reactions: mrjohnc1
When the battery “thinks” it is fully charged the DJI chargers will quit.
Reactions: Bobvt and mrjohnc1
Thank you for your observations. I appreciate it.
Reactions: mrjohnc1
I have noticed that it sometimes depends on the charger.
For what the info is worth, I usually charge mine with a USB ammeter in line and that when the display controller's display indicates 100% the ammeter is still passing reasonable current. I leave it charging until the controller's display switches off at which time the current through the ammeter drops to zero.
Same with me but when I charge from a small external phone battery charger it goes to 100%.As an aside I plug the controller into the external battery charger when flying and it stays above 90% for the equivalent of 11 M2P batteries.I have 7 drone batteries and a Smahtree external battery pack that will charge about 4 drone batteries from 22% or so to full.
Interesting ... I dont have the chance to see it because I typically stop charging at 80% or lower. My target has been to get it to 30 ~ 50% at the end of the day. From what I have read, that will maximize the life of the battery.
That's not much of a requirement for the controller. If it were, DJI would make accommodations or at least warn about discharging to 60% like they do for the AC batteries. Do avoid storing/transporting them in high heat locations for longer life, but there hasn't been many reports about controller battery issues.
Update: my charging of my M2 controller stopped at 99% after which it shut off the display. Trying to charge again for possible top off turned off seconds from start. I use the cable attached to the side of the stock AC charger to charge the controller.
That's not essential requirement but recommended practice for maximizing the longevity of lithium-based batteries. How to Prolong Lithium-based Batteries - Battery University
Reactions: Thomas B
Normal expected behavior.
Mine stops at 95%, but I only have it as a backup since I use SC 99% of the time, so no problem.
I doubt if it has anything to do with the # of cycles because SCCooper reported in his post above that his rarely-used controller has the same issue.
Interesting.... mine only stated this within the last couple of weeks after well over a year’s use and hundreds of flights on each.
Reactions: ssvdh66
volpe
