Hey guys,
I've just started experimenting with the M-log profile and :
although I can see that it has a better Dynamic range,
It appears to me that we loose a lot of detail due to the noise that is recorded (or rather not corrected)
I tested on the same background, with the same parameters (4K HQ, around 1/50, Iso 100, F5.6)
3 footages :
We can see that the highlights are less blown with the M-Log profile,
but the same footage with the Official DJI M-Log to REC709 footage darkens a lot the blacks/shadows,
the standard profile is well saturated, we can see a lot of details in the blacks ; and the whites are, as I said, more blown than the other profiles for sure
When I zoom on the middle of the image on the brown part of the seat I find that the M-Log profile is extremely noisy compared to the standard profile and we can't even dissociate the noise from the details. The M-Log + DJI LUT just crushes the blacks so that we don't even see what's going on there.
When I look on the blue rectangles of the pillow, it also seems a lot sharper on the standard profile than on the M-Log profiles
Although I see the advantage of having a wider dynamic range... Even after color correction, I'm not sure to be able to get a better overall result (noise, sharpness, color) with the M-Log profile considering I have to :
Will I really be able to get a result which has : better colors, better sharpness, less noise than the standard profile
What do you think ?
3 footages :
- Standard color profile H264
- M-Log profile H265 + DJI M-Log to REC709 Lut
- Color correct
- Color grade
- Correct the distorsion
- Denoise
What do you think ?
