M2P - Noise in video at ISO 100
Laursen
Hello fellow pilots :)
I'm really having issues with noise in both video and photos from the M2P. I feel like I've searched endlessly on YouTube and Google – can't find any solution.
Video is worst. I'm always at 100 ISO but since I'm not that technical skilled yet, I don't know where to put aperture and shutter speed. Therefore I quickly switch to auto – then back – and set my aperture and shutter speed based on auto-mode (does that make sense?). Overall I'm trying to put the white balance just to the right of the center.
I've attached two files. D-LOG and colorgraded version: noise_colorgraded.mp4 and 1 more file
I don't use any ND-filter.
Do you think there is a problem with my drone, or is it just me??
- Mathias
Reactions: Mike@Dragonfly
Manual settings
Exposure a 2 X frame rate
ND Filters if bright
AV at 0 or close too
Reactions: Laursen
I'm not going to download and run an unknown file from someone with one post. Can you upload it to YouTube or Vimeo and post the link?
- Mathias
posts like this are difficult to react to as it is not clear what your reference is and what you take for a standard acceptable noise level. so, if you compare M2P 1" sensor noise with a RED or even full frame DSLRs sensors - well, sure thing, it is not there and is significantly inferior. but if you compare it to M2Z - it is way better. so, it is all relative.
solution is - expose to the right using the histogram on the screen during shooting, make sure to shoot in the DLOG-M color to capture all 10 bit, then while in the davinci resolve - rotate the gamma wheel to get to the required brightness level. if you do not like the noise - you can apply noise reduction during processing, do not recall if you need to get a license for that or not. other than that - not sure what to say.
'we transfer', etc. - do not use that. give here links to your google drive, if you want to share.
Reactions: Laursen
Wiser people than I have said “there is no noticeable benefit of D-log” you’re just making yourself a lot of work and unless your an expert color grader then the end result may be worse. I use H265 which I thick gets you 10 bit colour depth & set the exposure, manual mode, carefully using the histogram and what u see. Make sure auto iso is OFF, use the lowest ISO that allows u to set 180 shutter speed, aperture around 5.6 or wider. I leave white balance in sunny day, unless it’s cloudy.
Reactions: Laursen
h.265 has nothing to do with color depth, it is a codec. but, you are absolutely free to do what you think is right.
I understand. It's also a difficult thread to start, because there could be so many factors playing a part in this problem.
Thank you for your advice!! I will definitely remember that next time flying. And also about WeTransfer – did not know it's a no go here :)
Thanks again.
Thanks a lot. I know DLOG requires a lot of skill and probably more than I have, but I will try get there :)
Thanks for your setting tricks!
InspectorTom
