M3 200fps mode
Etdronehome
Ontario
Too windy/cold to fly today so just powered up M3 inside to go through all the FLY menus.
I can’t find how to enable the 200fps the manual says is available. I know that I have to go into “Slow motion” to see the 120fps options but can’t find a way to choose 200fps.
Is this because DJI has yet to turn that option on in their current version or I’m just too simple to discover how to do it 😀
And you have switched over to FHD 1920×1080p resolution first ..? It's only there you have 200fps available.
These are the settings I have set in Camera. I’ve tried changing some of these and I still can’t find 200fps.
I am not sure if that is available yet with the current firmware. Please somebody correct me if I am wrong. Maybe in Cine.
I just confirmed with DJI support that the 1080 200fps in NOT enabled under the current environment.
The tech informed me that it would be included “soon” and will be accessible via the SLO menu as the current 120fps is now. I guess we will see when they actually make it available.
I guess that’s why I couldn’t find it!! 😎
This is interesting, because I have also contacted DJI about this. I can't find it regardless of selecting the correct resolution. My response from Jonathan.li was...
But in regard to H264/H.265 with 1080P@200*FPS, please kindly note that currently, it is only available with the 4/3 inch Hasselblad Camera. So if you are using Explore mode with the long-focus camera, it is not available to realize H264/H.265 with 1080P@200*FPS.
I'm not seeing it like others are not???
InspectorTom
