MA1 help
FpvnWV
Problem?error code 200
Was unit in a crash?yes
What have you tried so far?fact reset, replug cables
What device are you using ( iphone , ipad, Samsung , etc)?lg stylo5
What firmware are you running ( aircraft, remote controller)?latest MA 1
What Go app version are you using?go 4
Any modification?
(if so what)none
Did you change anything or install any apps? (if so what)none
Do you have a video or pictures of the problem? My question is this.... If you break an arm in a crash and order a new one, does the new arm HAVE to be soldered to the board or can you connect to the still remaining and undamaged wires? Just talking about the 3 motor and 3 lights wires.
can't help much, but i believe if you buy a new arm you will need to solder. you wouldnt want to risk doing some sort of splice to old wires and havign that fail and cause another crash.
To be honest it would be more frustrating to splice the wires together than to simply de-solder the old and solder on the new. Just use a little bit of flux and hopefully you have a narrow-tip for the soldering iron.
Reactions: FpvnWV
Much appreciated. After getting into it though, can see that some of the thin gimbal wires have also been broken. So time for more parts!
Corndart
