MA2 - Active track Parallel
XGrzesX2
PL
I have two questions about the active track in Parallel mode in MA2:
1. In this mode, is the reaction to the sticks delayed when changing altitude? If you want to change the height of the drone, you need to keep the stick long so that the drone rises. I did not notice this problem in trace mode.
2. I noticed that the drone does not keep the same altitude all the time. I set it at a height of 15m and there were moments when it changed to 5m (flat terrain, open field, number of satellites 21, KP index 1). It surprised me a bit because I thought that with the active track I would set a safe height that would not hit anything and it would keep this height. In the Trace mode I did not notice this problem.
O'Ryan
