Hey Com,
i wanted to share my newest expierience. Unfortunately it wasnt a good one. Yesterday I went out to the mountains and wanted to take some nice footage as I do oftenly. I found a nice spot not far away from the summit and prepared everything. Since it was a very rocky area, I decided to hand lunch, which I have done dozens of times before. Everything was set up and I had the conformation to fly. I pressed both sticks down and the propellers startet to spin - as always. So i pushed up the left joystick and the drone started to lift up in the air a few centimeters and then - suddenly dropped like a stone to the ground, hitting some rocks and and spinning on its back until it switched off.
I was super shocked and couldnt replecate the situation. Propellers had some scratches but still looked okish to at least check again if the MA2 still would fly. I searched a good spot nearby where I could ground start the MA2 with my extened legs. Ok everything was set up - no warning, so I started the motor again. I pushed up the left joystick again and the MA2 lifted in the air.. for around 20 - 30 cm before it fell down with its face forwad, crashing into a rock. Now the gimbal is damaged and I opened a case with DJI.
I checked the logs but couldnt find anything suspicious - howerver I am not a pro at all. Maybe somone of this forum can read something out of it.
"Flight" no1:app.airdata.com/share/cFLMNm
"Flight" no2.:app.airdata.com/share/vvEACb
I never heared or red anything like this before. I thought the MA2 was pretty safe to fly unless you are doing a pilot mistake. I am curious to see what DJI will say and /or do!
