If the remote controller mode switch is in the Tripod mode, when the controller and drone is powered up, everything looks correct. The C mode is indicated and when looking at the Safety screen, Obstacle Avoidance has both options lit, Bypass and Brake. If you select the Bypass feature and take off for a flight, it seems that the flight mode is really in the Normal mode and sideways movement isn’t allowed. If you try and adjust the gimbal, in the Cine section of the Advanced gimbal settings, it has no effect. If you switch the mode selector switch from Tripod to Normal or Sport mode and back to Tripod, it really changes to C mode and you can adjust the gimbal in the C mode . Now when you look at Obstacle Avoidance screen, Bypass is no longer an option ? .. only Brake! The Speed, response, and performance are as they should be in the Tripod mode. I'm not sure if I've missed something in the setup
Any help will be greatly appreciated
Thanks in advance
I have the latest Fly App update ver 1.4.3 and all the latest updates for the drone
Thanks in advance
