I purchased a set of Master Airscrew premium propellers and when I got them, they seemed kinda like a cheap plastic prop. Can anyone let me know if they are a decent upgrade, or if anything, what a good aftermarket choice would be. Thanks so much!
Any particular reason you're looking for 3rd party props?what a good aftermarket choice would be
I'm using the MA 'Stealth' prop's on my Mavic Pro Platinum [ DJI Mavic Pro & Platinum STEALTH Upgrade Propellers - x4 Orange ] . They are not cheap plastic by any means, they are a Glass Fibre composite construction, with very well engineered hubs. The design is quite different from the DJI stock prop's in both the pitch, and the design of the tips. I get better stability, quieter, and slightly longer duration flights using these (and that's compared to DJI 'quiet' prop's ...).I purchased a set of Master Airscrew premium propellers and when I got them, they seemed kinda like a cheap plastic prop. Can anyone let me know if they are a decent upgrade, or if anything, what a good aftermarket choice would be. Thanks so much!
No particular reason other than it was time to replace the props that came with my bird. I also purchased a set of DJI props. I just didn’t know anything about the Master Airs and wondered if I should have asked around before I clicked the purchase button.Any particular reason you're looking for 3rd party props?
Hey - you are welcome ... Besides, it will be nice to have someone to talk to when the DJI Purists burn us heretics at the stake for daring to use other than DJI prop's ...Thanks all, I appreciate the input. You guys rock!
There is a vid' that was made by Russ at '51 Drones' that does do a comparison:I have yet to see any side by side comparisons that show non OEM props are any better than DJI's. I am no Purist and follow some of the prop threads but I just have not seen any proof yet.
I've run some hover tests myself and have seen similar results, but must admit that tests are difficult in that you need to 'guarantee' somehow, that your battery is 'identical' for each comparison test run. I'm not a speed-freak so I don't know - and don't really care - if the MA's make the Mavic go faster ... But my tests and everyday use have definitely confirmed that a) I seem to have a bit more battery to fly with, and b) the drone is not as noisy - or - it is as noisy, but the sound is a bit lower in frequency, and therefore seems to be quieter.
Bottom line tho' is that we aren't talking significant dB's lower in noise, and significant additional minutes in duration ... So using MA prop's is not going to be an instant "YES - I WANT THEM!!" kind of thing, but saying that - there's just something about them that I really like! [Maybe it's the orange colour?] ...
Me tooI'm using the MA 'Stealth' prop's on my Mavic Pro Platinum [ DJI Mavic Pro & Platinum STEALTH Upgrade Propellers - x4 Orange ] . They are not cheap plastic by any means, they are a Glass Fibre composite construction, with very well engineered hubs. The design is quite different from the DJI stock prop's in both the pitch, and the design of the tips. I get better stability, quieter, and slightly longer duration flights using these (and that's compared to DJI 'quiet' prop's ...).
The performance of these prop's is far better than carbon-fibre equivalents ...
That's them ... Master Airscrew 'Stealth' prop's for Mavic Pro ..."there's just something about them that I really like! [Maybe it's the orange colour?] ... "
CharliesRig doesn't think he would have found his drone without the different colored props, no idea whose these are.
Not sure, but it seems like comparing props for noise / speed, etc, is a waste of time because there are too many variables, and because there is no significant difference that would warrant buying after market ones. No need to Re-invent the wheel. Of course that's just my opinion.There is a vid' that was made by Russ at '51 Drones' that does do a comparison:
