I just got mine a few days ago right after my Dad got his for his MM2 in red and I ordered mine in black and the only problem that we both had with them was just a fitment issue of the screws of which was both of our faults and what I mean by that is we didn't use the same screws that came with the MAS PROPS we both just reused the same screws that were in the OG PROPS and by doing that it caused a issue of causing the motors to work harder or putting a load on the motors or motor I never did figure out what exactly motor or motors it was but I did figure out that the screws would be to tight for the motors to work properly so I just took all of the OG screws out and replaced them with the new MAS PROP screws and problem solved and I have not looked at the screws side by side to see if one was longer than the other one but it probably was or it could have been the way the MAS PROPS were formed but either way it is absolutely fixed now and me or my Dad has a issue with our MM2 now and I have already talked to another guy here in the forum about this issue and I believe that he got his MM2 straight as well meaning if you have the screws to tight it will make the MM2 not want to take off or it will put itself in payload mode and or make it return to home without you telling it to cuz it is picking up the extra load or strain on the motor and or motors so just make sure you use the same screws that came with the MAS PROPS and not to tighten them up to tight and you should have absolutely no problems with them at all because mine is flying top notch now and I could not be more pleased with them, God Bless Sincerely Clay B.I hear all good things about these... thought folks? Thanks in advance
JG
I have tested mine today and unfortunately the drone and also the gimbal vibrate. I have sent an email to MAS but have not received a reply yet.I hear all good things about these... thought folks? Thanks in advance
JG
Yeah Brother I at first didn't know what to think about them cuz all I had done at the time was read about them and then low and behold my Dad pulled the trigger on buying some for his MAVIC MINI 2 and I had got to see what they were all about in the real world and I really was impressed with them so I decided to go for it and I bought some for my MAVIC MINI 2 and the rest is history and after having my own set of the MAS PROPS on my MAVIC MINI 2 I can truly say that they are AWESOME and I highly recommend them for anyone who is wanting a good upgrade for there MAVIC MINI 2 and or any other DRONE they have! Thanks again Guys for all of the Great information about the MAS PROPS! God Bless Sincerely Clay B.Bought them for my MM2 and love them, drone fly's perfect, definitely quieter, no vibration or drift. I use them on my Mavic Air, Mavic Air 2, Mavic Air 2s and now my MM2.. The MAS props always worked great for all my aircraft and no doubt give it an "easier on the ear" tone, and yeah, in the right conditions a lil better battery life too . Big fan of MAS!!
MAS for the MM2 work great, buy them while you can!
