Mavic 2 Pro Aperture Test (Sharpness degrades after f/2.8)
Doesn't really tally with things some of us others have mentioned - his methodology is a little odd too.
Ultimately it seems to be sharp at f/2.8, peak sharpness at f/4 and drops off at f/5.6
Diffraction starts to kill it at f/8 and narrower.
Reactions: Former Member
****....this means i'm going to need something more than an ND16...very interesting as I thought someone else ran the test and found F/4 to be the sweet spot. Maybe it just depends on the drone? Each one may be slightly different with tolerances?
f/2.8 is good,
f/4 seems best.
f/5.6 is perfectly usable.
f/8 is messier but not utterly unusable. f/11 is unusable.
I put my sample images here:-
Aperture sharpness results
So you've got 2 - 3 stops to play with on the drone. Get 1 x 4 stop and thats probably all you need.
mini3user
