So I just recieved my brand new Mavic 2 Pro and was really excited to start flying it. But when I downloaded the DJI Go 4 app and went to set it up, I got stuck at step 3 (picture attached) anyway why I can't link to aircraft? I'm using a Galaxy S8
Is the AC on? If so, does the display on the RC itself show "connecting" if it shows "connecting", then your AC and RC are not bound together. That would be unusual for all new, from the factory and never used pair.
Normally you would use the app to set the RC in bind mode, but you don't seem to be in a position in the app to enable it. There is a series of button presses on the RC to engage the bind mode from there. Once the RC is in binding mode, there's a button on the AC under one of those little flaps with an LED next to it. Press the button once. Don't use a stylus to press it or you might break the button off the circuit board. It's just flush enough that your finger should be able to engage it.
Assuming the RC and AC are connected (RC shows AC status), you may have an issue with the USB cable. If you are using the long cable connected to the bottom full size USB A port, you must disconnect the short cable from the side port to enable data on the bottom one.
If you are using the short cable, make sure it is properly connected on both ends.
I've found with my Android devices if I go into developer option and enable USB debugging it makes a huge difference. I've got about 50 flights on my Samsung Tab S3 and have never had an issue since enabling it Also make sure USB mode is set correctly, if your set to "file transfer" it won't see the aircraft.
Tried changing the USB mode and still doesn't workI would also think it's a USB mode issue. Only seems to happen to Android devices.
What mode did you change it to?Tried changing the USB mode and still doesn't work
