Mavic air 2 falls to the Ocean!
I was hovering because I want to take a nice pic. It was not in the 48 meg shot so I was changing it over. Then I look back in the sky and it’s gone!
Not sure if you have friends with a boat and scuba gear? Atleast you have a chance with DJI if you can recover it
Not really an option. We were visiting family. We did post on the local community pages to see if it gets washed up somewhere. Not holding much hope. ☹️☹️
The drone suddenly stopped transmitting telemetry data back to the controller when it was hovering at 47m. If the problem was on the controller side, the drone should have just hovered there but it was seen to plunge into the sea.
There were some problems with the vision sensors and IR sensors but they should not have caused the crash. The disconnection message was NOT due to the craft submerging in water but some catastrophic failure such as power loss or software crash while the drone was still in the air.
Technically the log alone should convince DJI that the drone malfunctioned. If DJI says no ask them what error you could have made to make this happen.
The drone suddenly stopped transmitting telemetry data back to the controller when it was hovering at 47m. If the problem on the controller side, the drone should just hover there but it was seen to plunge into the sea.
Yep I totally agree
Reactions: Deleted Member 997
You know I did an update to the latest firmware the previous day. Could that have contributed to it?
It's most unlikely that the firmware was at all related to the incident.
Ok I flew the drone the previous day with the same battery from 100%. It flew flawlessly. Put in back in its case and then did not fly again til the fatal crash. Battery was definitely in place. Just have to hope that DJI help me out. I believe I did nothing wrong
S
So sorry that you had this happen to you. I worry about this kind of stuff happing all the time. Flying especially flying over water. I hope DJI will see that you didn’t do anything wrong and will replace your drone.
Had a MA2 drop into a creek last weekend 'cause I was distracted talking to my buddy. It was under 4' of water for 5 min. Did a rice dry and it seems fine. Three things #1) Insurance. I pay only $60/year for all of my drones; #2) PhantomRain.org for RainSuit and Rescue Jacket. Just ordered mine this week. #3) Firehouse Tech Arc XL strobe and audible signal. Can help with retrieval.
The way I fly and film, crashing is always a possibility. I got lucky 3 times to retrieve them (twice in one week). Retrieval is key. Repairs are cheaper than replacement. I fly over wooded areas and water a lot. I'm not gonna fly over water anymore without my Rescue Jacket.
Flying over water is dangerous and risky. The manual says not too. So I doubt you'll get anything back from DJI
DJI have replaced drones that were lost flying over water, it does not void their warranty.
There's nothing that's particularly dangerous or risky flying over water.
Certainly there's nothing more risky or dangerous than flying over land.
Whatever you fly over, if the drone comes down, it's almost certainly going to be a write-off.
Flying over water is a lot like flying over land except there are no trees, powerlines, buildings or other things to run into.
On the plus side there are many great picture opportunities out there.
I've flown over 4000 miles over the ocean and I consider it's a safer environment for flying than on land.
I'm always looking at it from my point of few flying real aircraft.
Does that mean you took off the second day with less than a fully charged battery?
I really do not know how many post I have seen like this.
I guess it was enough for me not to fly over my lakes without the rescue jack.
I know it will not help you but maybe the ones that have been lucky so far to think again.
When I fly over water, I attach an aerodynamic shaped piece of styrofoam to the top of my Mini so if it does end up in the water I at least have a chance to recover it to return to DJI.
Yes, it flies a tiny bit slower, yes, the flight time may be reduced a little bit but at least I will get the Mini back (if I get access to a boat).
Reactions: maelstrom
mariovaleo
