Mavic AirCraft won't boot without a USB source
el0
Recently the Mavic AirCraft (AC) won't boot without a USB source (either RC or Computer) being attached via the USB cable.
Not sure why this is happening... The aircraft is 45ish days old and has not suffered a crash of any sort. I am running the latest firmware on both the AC and the RC.
What happens:
When the AC is booted W/O being teathered to the RC, the props rotate slightly, the wing lights turn red, the gimble calibrates and I hear the audiable boot chime. However the tail LED does not illuminate nor do the ultrasound sensors emitt the thumping sound. The RC will not connect
When I have the AC connected to the RC and boot the aircraft. the props rotate slightly, the wing lights turn red, the gimble calibrates , I hear the audiable boot chime, the tail lights rotate between yellow, red, green and the ultra sound sensors thump. The remote instanly connects. I am able to then remove the USB cable and take flight.
Does anyone have any recommendations why this is happening and better yet a solution to this...
Reactions: Mavic 57
Tagging along. This one is new to me. I suggest you extract a DAT file from the Mavic, one without the tether and the other with it.
There might be something in there that might give a clue as to what is happening.
Rob
Have you tried re-flashing the firmware? It sounds like its little brains are scrambled. Personally, I would reload the firmware, then recalibrate the IMU and compass to see if that doesn't fix the problem.
Rob
Thanks for the advice... Here are the interesting nuggets from the event log
2.654 : 11941663 : {root}INFO:lib_route_init ok
2.654 : 11942339 : {root}INFO:link_host_init ok.
2.654 : 11942533 : {root}INFO:link_init <0> link_host, ret(0x0)
2.654 : 11942706 : {root}INFO:link_init <1> link_pc, ret(0x0)
2.654 : 11943037 : {root}INFO:link_init <2> link_vo, ret(0x0)
2.654 : 11943212 : {root}INFO:link_init <3> link_sdk, ret(0x0)
2.654 : 11943527 : {root}INFO:link_init <4> link_ofdm, ret(0x0)
2.654 : 11943770 : {root}INFO:link_init <5> link_bat, ret(0x0)
2.654 : 11943980 : {root}INFO:link_init <6> link_auto_cali, ret(0x0)
2.654 : 11944232 : {root}INFO:link_init <7> link_cali_led, ret(0x0)
2.654 : 11944484 : {root}INFO:link_init <8> link_manual_cali, ret(0x0)
2.654 : 11945245 : 0 [L-SENSOR][ASR]sync host lead offset 0x11a
2.655 : 11946513 : 0 [L-SENSOR][ASR]asr host sync start
2.655 : 11948000 : {root}INFO:[panic]:******************check fault info and trace(0) ************
2.655 : 11948131 : {root}INFO:[panic]:-----fault info is null: addr(0x2045e800),flag(0x5429df83)-----
2.655 : 11948234 : {root}INFO:[panic]:-----fault info is null: addr(0x2045e938),flag(0xc0cf857b)-----
2.655 : 11948337 : {root}INFO:[panic]:-----all task info is null: addr(0x2045ea70),flag(0x3e4294b0)-----
2.655 : 11948448 : {root}INFO:[panic]:-----trace info is null: addr(0x2045f260),flag(0x77bffe92)-----
2.655 : 11948544 : {root}INFO:[panic]:******************check last trace ******************
2.655 : 11948635 : {root}INFO:[panic]:-----trace info is null: addr(0x2045eca0),flag(0x89c6eec1)-----
2.655 : 11948742 : {root}INFO:[panic]:-----wdg_time_info is null: addr(0x2045f820),flag(0x995cf509)-----
2.655 : 11949010 : {root}INFO:[link_ofdm] setup entry failed
3.851 : 17330656 : 0 [L-SENSOR] hw_ver voltage: 0
10.330 : 46486262 : 272 [L-ESC]escm ppm test finished 50
10.510 : 47296165 : 281 [L-BATTERY]req_auth_result_1 93
10.550 : 47475823 : 283 [L-BATTERY]call bat_auth_handler_1 length:39 3
10.550 : 47475943 : 283 [L-BATTERY]set_ack_result && set_reuslt
10.550 : 47476044 : 283 [L-BATTERY]bat_auth_set_result_origa
10.550 : 47476932 : 283 [L-BATTERY]GET_AUTH_ACK
10.591 : 47657478 : 284 [L-BATTERY]check result : auth success
10.595 : 47677869 : 285 [L-BATTERY]bat_auth_origa_stop
10.693 : 48118867 : 291 [L-FMU/LED]action changed. no atti:not converged(2)
10.870 : 48916728 : 300 [L-FMU]db data num: 230
10.871 : 48917313 : 300 [L-FMU]FATAL ERROR fail to get data 95 length for invalid src
10.871 : 48917642 : 300 [L-FMU]FATAL ERROR fail to get data 130 length for invalid src
10.871 : 48917836 : 300 [L-FMU]FATAL ERROR fail to get data 131 length for invalid src
10.871 : 48918000 : 300 [L-FMU]FATAL ERROR fail to get data 148 length for invalid src
10.871 : 48918220 : 300 [L-FMU]FATAL ERROR fail to get data 184 length for invalid src
10.871 : 48918369 : 300 [L-FMU]FATAL ERROR fail to get data 196 length for invalid src
10.871 : 48918480 : 300 [L-FMU]FATAL ERROR fail to get data 197 length for invalid src
10.871 : 48918597 : 300 [L-FMU]FATAL ERROR fail to get data 198 length for invalid src
10.871 : 48918708 : 300 [L-FMU]FATAL ERROR fail to get data 199 length for invalid src
10.871 : 48918814 : 300 [L-FMU]FATAL ERROR fail to get data 200 length for invalid src
10.871 : 48918928 : 300 [L-FMU]FATAL ERROR fail to get data 201 length for invalid src
10.871 : 48919038 : 300 [L-FMU]FATAL ERROR fail to get data 202 length for invalid src
10.871 : 48919146 : 300 [L-FMU]FATAL ERROR fail to get data 203 length for invalid src
10.871 : 48919349 : 300 [L-FMU]FATAL ERROR fail to get data 204 length for invalid src
10.871 : 48919524 : 300 [L-FMU]FATAL ERROR fail to get data 205 length for invalid src
10.871 : 48919690 : 300 [L-FMU]FATAL ERROR fail to get data 206 length for invalid src
10.872 : 48924266 : 300 [L-FMU]FATAL ERROR fail to get data 207 length for invalid src
10.872 : 48924517 : 300 [L-FMU]FATAL ERROR fail to get data 208 length for invalid src
10.872 : 48924648 : 300 [L-FMU]FATAL ERROR fail to get data 209 length for invalid src
10.872 : 48924762 : 300 [L-FMU]FATAL ERROR fail to get data 210 length for invalid src
10.872 : 48924887 : 300 [L-FMU]FATAL ERROR fail to get data 214 length for invalid src
10.872 : 48924994 : 300 [L-FMU]FATAL ERROR fail to get data 215 length for invalid src
10.872 : 48925141 : 300 [L-FMU]FATAL ERROR fail to get data 226 length for invalid src
10.872 : 48925250 : 300 [L-FMU]FATAL ERROR fail to get data 227 length for invalid src
10.872 : 48925360 : 300 [L-FMU]FATAL ERROR fail to get data 228 length for invalid src
10.872 : 48925468 : 300 [L-FMU]FATAL ERROR fail to get data 229 length for invalid src
10.872 : 48925561 : 300 [L-FMU]db_size:2814B
10.872 : 48925650 : 300 [L-FMU]debug module num: 78
10.873 : 48928525 : 300 [L-FMU]sa module num: 39
I agree with Qonncussion.
The firmware on the craft seems to be corrupted or incomplete. It's getting errors with certain libraries and then bypasses them.
I would suggest you reload the firmware again.
Rob
dewitt00
