Mavic Crash - Compass Error
drewdrones
Hong Kong
Hello Guys [I am looking at you @sar104]
I have a friend who took his drone out to fly and yes took off from concrete. I have attached the .DAT and .TXT files.
From what I can tell, there were a few GPS errors early on as well as just before the crash, but I was wondering if he hit the building or anything as such?
If you guys can shed some light i'd appreciate it!
  • 20-04-04-06-57-59_FLY558.DAT
  • DJIFlightRecord_2020-04-04_[15-59-07].txt
There's nothing in the flight data to suggest any compass errors or any malfunction during the flight.
The GPS Position NoMatch warnings at 0:21.9 are a common false alarm and mean nothing.
He was lucky with the concrete but not so lucky with his piloting.
The drone was flying under control and at 8:50.8 collided at low speed with something 209 feet above launch height.
As already said both by @Meta4 & @sar104 your friend backed the drone into the building ... nothing mysterious by that, it was a Mavic Pro without rear OD so nothing there to stop it in time. The navHealth & sat count also dropped continuously the closer he came that building ... all errors showing up were just a result of the impact.
If you want to have it more visualized I have attached one 3D view of the flight path showing the impact at the red cross at 64m (which sounds like a reasonable building hit height), after that it was virtually free fall.
Then also the flight telemetrics in the very end ... note what happens with Yaw, Pitch, Roll & Z-speed (in this case descend which max out at 22,1m/s) were the impact occurs there the markers are in the chart.
Reactions: Thomas B
NIKLM
