How long does it take to charge a mm battery?? It’s taken hours to charge my two battery’s, I’m charging them with the charger that came with the drone .. I’m not useing a hub just a single charge on each battery.. thanks
I think it’s the 18 w it didn’t come with a hubwhich charger are you using is it a 18 w one and are you using the supplied lead if you got a fly more package why are you not using the hub
I just got the basic not the fly more comboin the UK we only get a mains charger if we purchase the fly more combo with 3 batts if its the basic model we don't get a charger which one did you get
so check the output of your charger is it an 18w one, also do the lights flash quite quickly when the battery is being charged even if you have the correct charger and lead then the batteries will take around 90 mins to charge from 20% to fullI just got the basic not the fly more combo
The output is 5 v 1 a the lights blink slowso check the output of your charger is it an 18w one, also do the lights flash quite quickly when the battery is being charged even if you have the correct charger and lead then the batteries will take around 90 mins to charge from 20% to full
right you need to get a fast charger with a higher output and use the thick cable that came with the drone, the sort of charger you have will take a considerable time to charge them im afraid, it is ok for charging the controller i think you can go up to a 25w charger for the batts you can find them on the webThe output is 5 v 1 a the lights blink slow
Ok thanks for your help ill go get one this week. Thanks againright you need to get a fast charger with a higher output and use the thick cable that came with the drone, the sort of charger you have will take a considerable time to charge them im afraid, it is ok for charging the controller i think you can go up to a 25w charger for the batts you can find them on the web
I’m useing the charger and cord that came with the drone, I don’t know why they would use this when it takes so long to charge a batteryYou should be charging close to 2 A. As said, either the charger is not powerful enough or the cable is too light for the load.
I got it from dji brand new payed 399 for it. Its the mm fly more drone not the bundle packageWhere did you buy a basic package that came with a charger? All I’ve seen is the charger comes with the fly more combo. Unless you bought it second hand.
i am surprised you got a mains charger with it they don't normally come with one only in the flymore comboI got it from dji brand new payed 399 for it. Its the mm fly more drone not the bundle package
Yes it came with a white charger and cable and it’s 5 volt 1 amp. When I start charging it blinks very slow. I’m going to get something that charges a lot faster. I’m going to get one that is 18 volts that should do the job I hope.So you're mini only came with a white USB wall plug and cable, correct? And it's listed as 5 volt 1 amp? Something doesn't add up. I have an amp gauge hooked up to my charger and it will start at close to two amps with rapid blinking. As soon as it drops to one amp (near the end of the charge cycle) blinking slows dramatically. Do you possibly have another USB charger that is listed at more than 1 amp to try? You might want to buy a charger that will do more than one battery at a time. 90 minutes each
Ok my bad I will get one today and see if it works better. Thanks for your help18W not volt. But 5V 2 amp. ?
