Mavic pro 2 Accelerometer data error
I have no idea what that means. I am a newbie. Elaborate please.
Is it both accelerometers or just one? Can you post a screen shot from the GO4 app showing the sensors state. I had one accelerometer get stuck a while back on the Mavic Air. The method I used to resolve it was a little unorthodox.
Reactions: Prismatic
ACC0 the reads "Data Error"
ACC1 reads "Acceptable"
The Craft still flies excellent. No issue other than the IMU error..
I ordered a new GPS board + IMU.. It comes in Fri so as soon as I get it, I will update on pending "Surgery"
I loath any errors, indicator lights or things of that nature..
I would suggest hooking up the M2P to Assistant 2 and going into the IMU calibration menu; then observing if one of the accelerometers is stuck on one of its axis (like I did with mine in the thread I linked to in my earlier post). Replacing the IMU module may not be necessary if you can follow the steps I did and get it unstuck.
Have a look at this post and and the threads from the DJI Forums linked in there if you choose to go my route
Good luck!
Good luck!
Cool, will do. I did recalibrate the IMU with assistant however I was not watching any values. Will attempt again. I will also check your link. I have previously disassembled the craft to check ribbon connection and attempted to free stuck imu. It did not free up the IMU. I will give your suggestion a try. Thank you!
Flonke
