Mavic Pro Chargers
RENOT67
OK now I thought I had this licked, I have the combo pack so I have the standard charger and the car charger. I went for a flight today and decided to charge the battery I used in transit to the next flight location. So I hooked up the car charger plugged it in and attached the drained battery. I got a single led flash twice in position 1 and then off. I repeated the operation a few times with the same result.
Not off put by the incident, I decided there must be an issue somewhere so I hooked up a power inverter (150W) and plugged in the AC power adapter and the multiple battery charger adaptor and the drained battery. To my surprise the same happened?
What going on ?? The car was running in both occurrences so there was power. Shouldn't it be charging under at least one of the options?
tflys78
