Definitely sounds like an IMU error. If your Mavic starts to drift left or right, then you should check your IMU status. If you see an error message that say do not move aircraft while Initializeing, then turn off the rc then turn off your Mavic. Restart the rc, and your Mavic, then calibrate the IMU. Make sure your Mavic is on level surface.Just back from Georgia to NEBR. Test flight today and discovered
slight drift to left, very very slow, and stirring in flight again slightly.
Is it a compass (x2) issue??
Point me in the right direction please.
Most of the time, it's a simple solution.Remember, there's a lot of people on this forum, so there are no easy questions.
