Mavic Pro Slowly Rises instead of Hovers
swright
Hello fellow pilots,
Today I flew my Mavic Pro for the third time, and it was quite enjoyable. However, when I was flying the drone back to the home point, and pulling the left joystick down (to lower the aircraft), I noticed that every time I let go of the joystick, the Mavic would slowly rise and keep doing so until I permanently held the stick in the "down" position.
Has anyone ever experienced this? I live in Florida where it is flat, the wind speed was wsw 3mph, and I flew it around 6:30pm (about 30 minutes after sunset).
This normally happens when the downward sensors incorrectly detect the ground is near. Here are some of the usual causes of that false detection:
  • Something is dangling beneath the Mavic (e.g. a GPS tracker antenna)
  • A 3rd party accessory is installed beneath the Mavic (e.g. extended landing gear)
  • The sensors needs to be calibrated like this
  • The sensors are dirty and need to be cleaned
  • The sensors are damaged and need to be replaced (not a common problem)
This issue can be resolved mid-flight by disabling the Landing Protection setting. You'll find that setting in the following section of DJI GO:
Reactions: FLYBOYJ
Azra
