- Joined
- Sep 25, 2018
- Messages
- 18
- Reactions
- 9
- Age
- 65
I have an MP1 that has flashing red and green lights as follows: flashing red 2X and then flashing green 6X then flashing red 2X and then flashing green 6X as so on. What does that mean?
More info! Have you ever flown your drone with the controller you have? I understand this to be an initial linking.... correct?Yes! Motors off, trying to bind controller and Mavic.
Are you using a computer with DJI software to do the binding, or only using mobile devices?I have NEVER flown this Mavic. A newbie. I am in a NFZ as well. I've gotten it to bind only 2 times out of about 20-25 times trying to bind. Any words of wisdom?
Nope, on my android phone. I do not have any image from my Mavic.
So if I keep trying to bind I'll fry something???
You don't have to bind every time you power up. The aircraft remains bound to the controller. Make sure the switch by the SD card slot is on "RC" instead of "WIFI".
OP, the drone is bound already. Can you see an image on your screen? If it were not bound, the rear LED would be flashing yellow. Dont keep trying to bind it or you will fry something.
Hi H.A,If you try to keep binding it, you risk bricking the drone, especially if its already bound.
