Mavic2 pro drifting
lebaneso
Lebanon
My m2p deifting to the left side from time to time and when i push the stick to the right it stops what do you guys thing is causing this and how to fix this issue
Could be an issue that calibrations wont solve. Calibrations are not a
cure all. Some history on your hardware would be helpful.
Any crashes? Aircraft had any work done internally? Original owner?
Props have no flaws?
There will be a reason for what you describe, just needs to be found.
Reactions: Meta4
See this video.
When you try to calibrate the IMU you should see the status so you will know if it needs to be calibrated.
The above looks good.
Also just check that the blades are all in good order.
I have had that happen a couple of times with my M2. After recalibrating compass, IMU and sticks, it returned to super steady like it was new.
Try:
Enabel Downward vision Positioning
unde: Advanced Setting
phoenix_00002
