I've read the several threads on the subject, including those @msinger links to within some of them. I'm still confused about the sequence of events related to logging into dji, and it "remembering" your settings. I thought one said that once you do that once (while logged into the app), you may then disconnect wifi and cellular, and fly on.
But in this case, I was flying fine; no limits in max distance (I had it off). I swapped the battery, did not quit the app, although I was in airplane mode at the time, and all of a sudden the max distance was set to the default.
What is the proper sequence to get this set so that it stays where I set it (no max distance)?
