I might buy 2 64’s instead then. I just wanted to upgrade to a faster cardHere is a SanDisk on Amazon:
https://www.amazon.com/SanDisk-128G...ocphy=9010813&hvtargid=pla-588455240877&psc=1
Can I ask why you need such a big SD? I never use more than a 64 because I never trust an SD card once it has been in a drone. It's good for recording until I can offload at home. Then it gets wiped clean for the next flight.
As alluded to before, regardless of size get the fastest card you can. I also prefer Sandisk. I have used all sizes, but 64G is plenty even with 4k and will save you a few bucks.
That is what I said.With wear leveling (built in to the pro sandisk cards) it spreads the writes evenly across the memory blocks. Therefore they last longer ie more reliable for longer. Audacity Find My iPhone Origin
8GB worth.How much video can the inbuilt storage on he mavicpro hold ?
No matter what storage size SD card you want - for whatever reason, there is really only one important and relevent spec' you should be looking for on the card, and that's the 'UHS Speed Class 3' logo - which is the U with a 3 inside it. U3 cards have the ability to sustain a minimum write speed of 30 MB/s (MegaBytes per sec'). That's the capability that you need for the card to accept a continuous stream of HD video data without being overloaded and dropping video frames. Pretty much every other spec' on the card is irrelevent in regard to the recording of video by the drone.
XCII cards are expensive, because they have a faster read speed, and with the right card reader and PC, can be an advantage in that the time taken to get the video from the SD card to the PC is reduced - but XCI or XCII have no impact on getting the data onto the card in the first place!
Yes - you are experiencing the confusing marketing that all these little symbols and markings mean on the cards ... The card might be able to do 'something' at 100 MB/sec (and that probably should be 100 Mbit/sec rather then 100 MByte/sec) - but it's not clear exactly what!I noticed some U1 cards are advertised as being 100 MB/s.
https://www.amazon.com/SanDisk-Ultra-microSDXC-Memory-Adapter/dp/B073JYVKNX/ref=sr_1_4?crid=72D3UP3R8LS2&keywords=micro+sd+card&qid=1552791993&refinements=p_85:2470955011,p_n_feature_two_browse-bin:6518305011&rnid=6518301011&rps=1&s=pc&sprefix=Micro,electronics,216&sr=1-4
Will these be fast enough for all 4K formats of the M2P or is it safer to go with the U3 cards?
Some dealers are throwing in 128 GB U1 Sandisk cards so it's kind of tempting to try that one. Though others are throwing in the Samsung Evo Plus:
https://www.amazon.com/gp/product/B07H5WT1H9/ref=ox_sc_act_image_1?smid=AKQJFK3IW4Y5Y&psc=1
