Hi Dale. Sorry I didn't pick up on this thread earlier, but as you may already know I was on vacation without good internet access. Sorry to be late to the party but perhaps I can add to the conversation regarding strobes and ND filters for the
Mini 2.
Like you my main drone is a
M2P and I have ND, PL and gradient filters for that one. The
M2P camera is so much easier to operate where ND filters are concerned because you only have to get in the ballpark with an ND filter and have a 4 stop aperture adjustment to play with after selecting one and then dialing in the shutter and adjusting when in the air. If I need a cinematic effect I'll just fly the
M2P. My
Mini 2 is more for recreation and fun. FWIW on this vacation I only took my
M2P. For touring I used the original FMC bag and limited what was in it to the drone, controller, batteries and filters. While the
Mini 2 would have been lighter I didn't find the M2 burdensome at all to have it on my shoulder for 10 days.
Strobes: Firehouse has a number of options and I have explored most of them. I typically fly my
Mini 2 with an Arc II on the bottom or alternately an Arc V. Unlike others who have the 3D printed bottom mount I use velcro. It works fine. The only caveat is that you have to be a little creative because it has to be mounted creatively around the switch and battery condition lights so you can't mount the light until you start the
Mini 2. I have a piece of velcro on the top and park the strobe there until after the
Mini 2 is turned on. It takes two extra seconds and saves weight. My Arc II has that bottom option, but I ordered a top "headlight mount" but got it separately and modded it so that I could take the Arc II in and out of that mount. I tend not to use it much because now I have smaller red/green strobes currently mounted on the arms, but will, as of today use the headlight mount for one of the smaller strobes and mount the other on the back. Green in front red in back- or vice versa? I have to look that up.
Edit: Note that on the arms the strobes are mounted via cheap elastic hair bands. I got several hundred of them for $2.59. In reality two is sufficient to hold a strobe on. You have to be careful with velcro. Standard HD velcro is more reliable than the stuff that Firehouse provides. I've lost two strobes with their velcro, so I supply my own.
Lots of combinations in photos below.
View attachment 131812View attachment 131807View attachment 131808View attachment 131809View attachment 131810View attachment 131811View attachment 131812
