Mini is in boop loop after firmware update that was not completed.
Try to use the PC but it disconnect every time after boops.
Contact DJI and describe that issue...not sounding good. You should be able to use Asst 2. to refresh firmware, if it won't connect Then either you have wrong Asst. 2, Driver issue or just a bad Aircraft.Mini is in boop loop after firmware update that was not completed.
After tried the update using the dji flyapp I notice that the update starts at 40 % and after 47% the app says that lost the connection with the aircraft
My problem is that the drone do not stay on enough time to be connected to the PC ( I can see the drone connect but when trying to read the firmware installed it disconnect ) or to keep connection to the fly app.
